Hi,
Do you know if it support wrist HR detection with the latest sw update ?
Is it accurate enough ?
Thanks
Hi,
Thanks
@tmk2 Is correct that this was brought in with update 3.10.
In regards to accuracy, using a heart rate strap will produce the most accurate readings while swimming.
The changelog says that since 3.10 it does
Define "accurate enough". Generally…
Define "accurate enough". Generally optical sensors are notorious for inaccuracy even for non-swimming activities, so do not expect it to work any better in water.
