I'm wondering how to change the pace to display in minutes/km instead of minutes/mi. I've already changed the global setting to Metric.
From what I remember I changed the Lap distance from 1.6 km to 1 km.
Start the Running activity Go up for Options - Run Settings - Auto Lap - Auto Distance
You will have to do this for other activities…
The correct answer is that there is a separate setting to change this:
That does not actually change the pace setting. As you will see above, Mr 8600388 expressly said he had already changed the global setting to metric - but that does not do it. I am having the same problem. My theory is that this is because I set it up as as being based in the UK. It seems like a bug.
I have the same issue. First of all I don't have "System" under "User Profile".
"System" is located directly under the "press up" menu. There I can select units.
I changed "Pace/Speed" to "Kilometers" but the watch still shows my miles when I'm on a run.
Has anyone found a fix for this?
Note, I am using the Forerunner 245 Music.
You will have to do this for other activities a s well if needed as it is not a global setting on the watch
Hope this helps
