Is 245 able to show current altitude during the sport? I know that there is no altimeter, but there is at least GPS and Elevation data field available.
Also is possible to install some altitude widget?
Total elevation gained is available to Connect IQ apps / data fields. I would normally point you to a dedicated field for this, but it looks like the only one I know of hasn't been updated for 245.
Instead, you can install my data field AppBuilder 5 and use the following settings:
Formula: TotalAscent
On devices without a baro, Ascent and Decent could be quite odd, I've seen 400' when it was closer to 40')
I'm sure that's part of the reason there aren't native DF's for that.
For non baro devices, when an activity is uploaded to Garmin Connect, "elevation correction" is applied to the data to help things look better.
