Does 245M Treadmill correction not affect Strava Linked Runs from Connect. I corrected to 3.02M but on Strava it still showed up as 2.34???
Ideally, Strava would upload the in your file after your calibration, but we will not have any control over what Strava does in their processing. I have personally seen differences in my own data between…
This is not true. The issue is entirely on Garmin's side.
Using a Fenix 5x watch, and calibrating to 4.00 miles from the 3.62 it recorded as the treadmill distance, Strava does report the incorrect…
You are correct. Garmin just updates the total distance at the end of the activity file. It doesn't go back and adjust all the individual records. You could argue for it to be either way. The records…
This is clearly not a Strava issue. The data is saved and uploaded to the Garmin platform before the user has a chance to calibrate.
This is a super disappointing setting, and could easily be fixed with a few lines of code. Garmin, please help and fix this.
endomondo imports the corrected time, strava no.. so this is a problem in strava..
Unfortunately no … Carlin’s fault… I do a watch distance calibration on my watch before saving it and still Strava takes the incorrected distance … weird
as if Garmin sends it to the server and let you calibrate after …
SOLVED: I built a free tool that allows you to download your treadmill run from Garmin and sync it to Strava with the correct distance info while maintaining HR and other data!
Give it a try here: https://www.stravatreadmillfixer.com/
