Battery Life 245M
After a week of use of the FR245M I’m experiencing battery life way below the claimed 6/7 days in smartwatch mode.
Currently a full charge with no recorded activities, no music playback and observing some of Garmin’s battery saving advice such as using a watch face with no moving seconds and turning off pulse Ox and notifications is getting me just under 48 hours before running down to 0%.
I am still using the heart rate /sleep monitoring etc but I consider these to be normal metrics for smart watch mode.
Am I missing something here? Is Garmin’s claim for 7 day battery life based on operating in ‘basic watch’ mode only with all monitoring turned off or have I bought a dud?
  • Cant say im getting stellar battery life either to be honest. Charged yesterday morning and now (7pm the next day) am on 62% battery) .. i'll push it to 4 days possibly but my VA3M had better battery life than this
    I'm also experiencing poor battery life with the FR245. In watch only mode I'm seeing 40% battery drain per 24 hours.
    Current Settings:
    -Phone notifications disabled
    -Simple digital clock watch face
    -Backlight set to 8s
    -All activity backgrounds are set to black
    -No ANT+ devices connected
    -HR is ON
    Curious if there is a setting that needs to be changed or possibly a firmware bug? If this is realistic battery life, its quite disappointing.
  • I came here expecting to see the opposite. Mine has been better than expected, less than 10% per day if I don't use GPS. I only have phone call notifications enabled and I sync to an iPhone xr.
  • using watchface with seconds, continously HR-monitoring and no BT-connection to phone and loosing roughly 10% per day. Works perfect for me
    0 Former Member in reply to kehanra99
    Do you have heart rate enabled?
    Agreed, mine has been better than expected as well. Everything enabled (including HR, notifications etc) other than night time PulseOx and if I don't utilise GPS on any given day I'm only dropping by about 9% every 24 hours.
    I thought I’d found a solution by letting it run down to zero a few times before a full charge. (It sometimes helped with the constant battery issues I used to have with my old 405).
    It then only lost around 10% in 24 hours.
    I then I used it with GPS enabled for a half marathon which still only dropped it to about 80% but after this it lost 30-40% per day as before.
    Looking at the responses it looks like I’m in the minority and have a watch that’s not quite right.
  • Mine (not the M version), with auto light in night only, continuous HR, 4 hours GPS+Glon per week and arround 20 notifications per day, not wearing at night and turning it off, lasts 8-10 days. This is enough for me.
  • The Garmin watches probably come with Li Ion or LiPo batteries I'd guess? Shouldn't you never ever discharge them to zero? I think this basically destroys the cells, and the advice for laptops for example is to *never* discharge them below around 15%. (Also charging them from around 92 to 100% is supposed to be another really bad thing, which is why ThinkPad's for example have a mechanism where you can stop charging at around 95%.)
  • Same here. I'm going to try running it down to 0% and give it a full charge. I think I had this same problem when I got my 235 a few years ago, and it eventually ironed itself out. Hopefully this watch does it too
