Weather
Hi all!
Why is the Garmin weather off by about 3-5 degrees, always? Right now my iPhone and Mac tell me it is 15 celsius outside; usually my car tells me it is about the same, plus or minus 1 degree. My FR165 tells me it is 12 celsius outside. What gives? Curiously enough, I installed a third-party weather App and it does tell the right temperature. However, I did not find a way to put a temp widget on the watch face that reads this other value instead of the default. Any way to either correct Garmin weather or else to put a widget in the watch face that connect to a third-party app?
Many thanks in advance!
Cheers,
Desi
  • You are not the first person to comment on this. Its because of teh (limited?) weather stations Garmin uses. If you google you will see many comments and background to it. Look on GarminIQ for a different app with widget , some have same AFAIK.
