Screen timeout not working
I'm on beta 20.23 and the screen timeout is not working on screens like glances, system menu, controls menu. I have AOD set to off, timeout to 4s for general use. The only place it still works is the watchface.
I'm not sure if this is intended or a bug, but this behavior means the watch is now at risk for burn-in if I don't notice that the screen isn't off and I don't manually navigate back to the watchface. It will automatically return to the watchface after about 2 minutes where it will switch the display off, but in that time it uses extra battery and contributes towards burn in.
I'm going to have to turn off touch in case an accidental swipe opens the glance view and I end up with burn-in on the screen. Please fix this.
Can someone who isn't on the beta version please check if they have the same behaviour or if the timeout works? Thanks :)
