Is it possible to display the altitude above sea level somewhere? It says that the watch has a barometric altimeter but I can't find a setting to display that...
Maybe if you look at this widget?
Running , cycling start an activity and set up the screens how you want
Have you looked at the Glances on the watch , I have a different watch so I am not sure if yours has the ABC Glance
Yes I found the ABC Glance from the first comment and it works, is there also one for speed for example when I am in the car?
Great! Usually you can find stuff like this by browsing the Connect IQ store. In your case by browsing the results of
https://apps.garmin.com/search?keywords=widget+speedometer
Since the Forerunner 165 is fairly new, not all results will work (yet) on your watch. In that case just click the link 'Contact Developer' and kindly ask if a version for the 165 can be made available. In a few months, most active developers update their software and make it available on the 165 anyway. I make it a habit to at least buy a "cup of coffee" for the developers for the software that I use.
Anyway, hope this helps!
