HRM Pro Plus question
Hello all,
I got the strap yesterday and went on an outdoor run with it today. I have a few questions:
1. Do you manually disconnect the strap while not in use in the Sensors tab? I do it when using my headphones so the watch will not be constantly 'Searching' for them.
2. If I understand correctly I can enrich the watch data with the HRM data on the last screen with all the statistics when I have the HRM connected? So unless I set Pace/Cadence on the strap to 'Always' I need to do it manually each time? If I set it as such and don't wear the strap it will use the wrist-based data?
3. The run got recorded twice, so I deleted one entry - is this a well-known bug?
Thank you!
Top Replies
All Replies
