Update 0.0.46 made accuracy worse in erg mode compared to 0.0.45.
I've seen a lower estimate of about 2% where before it wasaround 1%
Can you explain that ? I use the bike mostly for ERG training and (training peaks) would gladly skip that firmware
The updated firmware is showing power as much more jittery in erg mode, and it is consistently running a watt or two lower than before for the same workout (looking at 30s power averages to smooth it). I…
The updated firmware is showing power as much more jittery in erg mode, and it is consistently running a watt or two lower than before for the same workout (looking at 30s power averages to smooth it). I am assuming the jittery data is due to the 10Hz reporting with power, the new JetBlack firmware disables 10Hz mode in erg mode because of it causing problems like this.
what is the new FW JetBlack?
It is a smart trainer, in fact it is the same model that ZWIFT sells
