My left pedal knocks on the upstroke, and both pedals slip when I'm up in the saddle - any thoughts on both or either problem? I've only had the mike for two months. thanks.
What crank arms do you have the original or the new one ?
just got the bike two months ago, pretty sure they are the new ones
Do the crank arms have 3 holes for the peddles or just one ?
Just make sure the screw on the left crank is tight my first one did the same they feel tight but need nipping up, make sure you put the head of the driver in properly
Thanks. Had same problem with knocking noise. After tightening left crank screw and quick test seems to have gone away
Tightened everything up - now it's worse.
So tightening the bolt on the left cranks made it worse. From that video it sounds like your tension roller I’d send it back
and it is louder at higher watts - and after climbing - i have a support ticket open, How do you send it back?
