Unplug when not using?
Should the Tacx Neo 2T be unplugged when not in use or is it fine to leave it plugged?
  • Power draw is less than 5 watts (and probably much less) at idle.
    Since there is only rare firmware updates via the app, there is no background updating to be expected.  Though the new 3-series might be different.   Additionally, always being plugged in exposes any electronic device to potential electrical surges.
    Saying that, I purchased a box of smart plugs and had one to spare.  I wanted them for some floor fans and the like.  Adding one to the Tacx was an easy add.  Now I power it on/off along with the primary fan. Additionally, I bought a wall receptacle surge protector for that specific outlet.  $25 to protect an expensive trainer.  Which in my use case means I don't have to unplug and I can easily power it down.
    There's no downside to disconnecting it if not on a surge protector other than convenience.  When not in use a voice activated power solution and a surge protector is nerdy or slick depending on your personal view.
    Smart wall plug for Tacx
