After my first ride, Garmin connect show the crank length to be 175mm. The correct length is 172.5mm. how do I change that?
Latest firmware is installed on Neo 2T.
Garmin Connect is on auto update.
Doesnt matter what kind of crank length you have on a 2T :) that is only needed if you have a pedal based powermeter and there the crank length is a factor for the power calculation
