Motion plates and Front wheel support for gravel bike
Hello,
is there a solution for the front wheel support of the motion plates when the front tyre is wider than 28mm? My gravel bike has 40mm…
  • I have the same issue......seems only chance is to install a front wheel with 28mm tyres.....
  • how supported do you need the front wheel? can you not just shim the height of the front wheel until the axles are level? that's what I've done the couple of times I've put my gravel bike on my neo 2t
  • I tell my experience with the front wheel support but with road bicycle if it can suggest to yuo any other solution.
    I dont' know if it is correct to say but for my comfort I removed any front wheel support. My front wheel is put on a tile lied on a trainer mat.
    First i have a better feeling putting the wheel lower and second the wheel is movable and this gives me an further degree of freedom.
