Neo T2 (10/2020) connected to Lap top via BT, until last week, no problem.
The connection with ANT +, even if with the original Tacx antenna, never worked.
From 26/05/2021, the trainer does not respect the power required by the personalized training program in ERG mode on the Tacx Dekstop App:
in ERG mode 100 watts are required but the pedaling is light and the watts oscillate from 70 to 100 according to the rpm.
Subsequently, when the program asks for 150 watts, the brake does not increase and nothing changes. If, I engage a longer gear and increase the force I apply on the pedals a lot, suddenly, the brake resistance increases a lot and the Watts are above 150 required but, however, they are not stable and fluctuate according to the rpm from 130 watts to 290 watts.
If I use Tacx neo T2 with Zwift installed on the Lap top, no problem, it works perfectly (even with ANT + connection)
Even with smartphones, the Tacx neo T2, also in BT, works perfectly.
Tacx neo T2 updated to the latest release
Tacx Desktop App updated to the latest release
Can someone help me ?
Thank you
