Assioma powermeter vs NEO2T power accuracy
Yesterday I upgrade the firmware of my assioma pedals, the new FW now has automatic calibration
Now I see that my power readings Assioma vs NEO2 are within 1%, whereas previously it usually differed 3 to 4%
I should do some more comparisons before I cry victory, but it certainly does look promising
  • Good hint, I'm going to check this now.
    As for now I have -3.2% manual adjustment set in my Assiomas to match power readings from NEO2T. If automatic calibration in the pedals will help to reduce this gap then I will be more than happy.
    Did you have a chance for more checks?
    Thank you,
    Jarek
  • I did a second ride and again overall difference is less than 1%
    when zooming into the data it fluctuates a bit, but rarely more than 2 to 3% for any segment of 1 minute. With the previous firmware, the fluctuation for a 1 minute segment was frequently around 6%
