Any more concerns with Accuracy?
My 2t shows 5% less than my power2max ngeco. Tested with two neo 2t units.
Not happy.
Same here, check the other thread... Not happy. Especially when Garmin says it is due to drivetrain losses... Well why then Neo and Neo 2 are tracking the same as Favero Duo?
I thought from your last post, you were getting 1-2% accuracy already? Is that not the case? Have you tried contacting support and requested a re-calibration for your NEO 2T?
Unfortunately not, perhaps it was due to low-intensity work that I was doing, so the deviation was not that big. I have even changed my powermeter from Favero Duo to Quarq Dub AXS - same results against Neo 2T - in medium/high intensity we can see hikes from anywhere between 5-7% all the way to 11-12% in the sprints.
Very happy, my Neo is spot on compared to my Assioma Duos
Which firmware are you on?
Neo or Duos?
0.0.34 and 4.25
thanks, same here... Well, one thing that I can attest is that at least it is very consistent reading from Neo 2T. I gave up waiting on another firmware so I know that I have to work with 2 FTP settings - indoors (on Neo 2T) and Outdoors (on Quarq). The latter reads higher so a bit of a confidence boost as well
