hi. anyone else have problems with rear mech rubbing on trainer. I am using campag super record and in lowest gear the mech runs unless I adjust it to almost not changing properly!? it says don't use spacer but should I ?
Yes there is a fine spacer ring it is still very close but just works also check your derailing hanger is not bent.
OK, cheers
