GEAR FOR CALIBRATION
Hi all,
Can someone explain with which gear i should calibrate Tacx Flux S?  I try to explain better:
Each time i start a ride, the app asks to calibrate the trainer. I usualy put 50x11 reaching the speed required. The problem is that even if i start with a descend of 15% it seems i am pushing a 80x11.
This causes i have a lower gear ratio for the climbs and honestly it is difficult to understand when i can push or not
Can someone help me on this?
There is one gear ratio that could be fine to make the ride most real ?
Thank you all, really
