Firmware 3.3.40/1.1.6
like the noise problem wasn't enought ,now since the ffirmware update i'm constatly having connections problems and incorrect power mesures. so whem a fix to this....i can't give a name....firmware?
Thanks
JLopes
  • Beside the noise, I have the same issue with this update. The strange think is that today in the Tacx utility the menu for update have in brackets "not available". Let's see when will  be available the fix.
  • let´s hope, for S they have alredy solved with a resotre (http://download.garmin.com/support/Fitness/Tacx/Flux_S/restore.tacxfirmware) i have try to see if exists one link for flux 2 with no success Disappointed
    Since the latest update ERG Mode no longer works, anyone else with this problem?
    0 Former Member in reply to jersl
    Aquí tambien problemas con 1.1.6. Mide muy mal la potencia. Muchos saltos. Espero soluciones pronto. Es increible que una actualización de estas cause tantos daños...
    The same problem, incorrect power measurements, unexpectedly watts variations,
  • Hi, a firmware 3.3.40/1.1.2 was se to me, I’ve downgraded my trainer and it’s more stable
  • you have to rename to tacxfirmware, then send you your email, and open from the phone,  select open with tacx utility, go to update Slight smile a do the downgrade
    Hello. its for flux 2?
    thanks.
