Hello,
I'd like to configure the wheelsize in my edge 1030 device. In the menu I can see the wheelsize and the ratio parameters but I can't find it that info. Please. could you help me to configure my Tacx flux 2?
Thanks in advance,
David G.
Hello,
Thanks in advance,
David G.
I just bought my Tacx Flux 2 and am trying to find this data, I just found 2620 mm (in other forum for the Tacx Neo 2). I haven't used this setup yet. Hope this helps
Hi Corts
After using it I discover that the speed data is not wheelsize dependent, I mean, it doesn’t matter which wheelsize you use because the trainer sends directly the speed.
You can check it with the tacx apps, the speeds in the edge device and the app are the same whatever wheelsize you use.
King regards
