Tacx Training Desktop App keeps shutting down after showing main window for 5 seconds
Hi
Shortly after starting the desktop app it keeps closing on me as if scripted after connecting to a profile server or something like that. Tried about everything to resolve this; repair app, reset app, reinstall app, disable Windows Defender etc etc.
Never has done this before for the last so many years.
Started after December 15 20205.
  • Ok for future reference I figured the problem out.. or at least.. AI did ;)
    Root Cause (final)
    AntService.exe crashes because WMI event subscriptions are broken on your system
    Specifically:
    • AntService tries to create a WMI watcher for Win32_PnPEntity
    • WMI throws WBEM_E_INVALID_CLASS
    • AntService doesn’t catch the exception
    • .NET aborts the process
    • Tacx shuts down seconds later
    This is 100% deterministic and reproducible.
    Why reinstalling Tacx alone does NOT fix it
    • Tacx ships AntService as a packaged Windows App
    • The crash happens before any Tacx code can recover
    • The problem is in Windows WMI, not the app
    That’s why:
    • Reinstalls don’t help
    • Driver updates alone don’t help
    • Tacx closes “mysteriously”
    White check mark Correct Fix (Do This — In Order)
    1️⃣ Repair WMI (mandatory)
    Open Command Prompt as Administrator:
    winmgmt /verifyrepository
    If it says inconsistent (likely):
    winmgmt /salvagerepository
    Reboot.
    2️⃣ If AntService still crashes → reset WMI
    winmgmt /resetrepository
    Reboot again.
    Warning️ This is safe and commonly used by Microsoft support.
    3️⃣ Rebuild WMI performance counters (often required on Win 11 24H2)
    lodctr /r
    Then:
    winmgmt /resyncperf
    Reboot.
