Flow smart trainer thru axle confusion
Hello,
I have a Orbea Avant H60 bike and I have also bought a Tacx Flow Smart trainer. Now I'm a little confused about axle compatibility. My bike has double-lead thread pitch so the original Tacx are not compatible (for example the T1711 model that was the closest but it has single lead thread pitch).
I have found original Orbea trainer axle (X056; www.orbea.com/.../x056ttcc) and also Robert Axle Project Trainer Thru Axle - TRA224 (www.bike24.com/p2595128.html). Orbea cannot guarantee the compatibility of their trainer axle and recommended that I contact Tacx. So my question would be if anymore can confirm that for example the Orbea's axle length 183mm would be suitable for Flow Smart Trainer? Robert Axle has a length of 165mm but I'm not sure if it's double-lead type (at least it seems to be). Also not sure if the caps of both (Orbea and Robert) are compatible with Flow Smart.
Bike's axle info spec is following 12x142mm (Thru axle); 12x165mm in total length; Double thread 2P1.0; thread length 15mm.
Thanks in advance!
