I used my Mac the first time with the Tacx Flow to see differences between the different software versions.
iPad does record cadence, Mac doesn‘t. Anyone seeing this behavior?
then I wondered how can the tablet record cadence without the sensor?
The software determines the cadence from the roller acceleration. This is not a very accurate measurement, especially if you pedal very evenly…
So better to use a cadence sensor then?
Yes, it will make the measurements more accurate.
Is the Tacx app able to connect to that via Bluetooth?
Sorry, I can't give you a straight…
How does this work?
The software determines the cadence from the roller acceleration. This is not a very accurate measurement, especially if you pedal very evenly around the circumference.
Thank you Alex. So better to use a cadence sensor then? Is the Tacx app able to connect to that via Bluetooth? I saw the sensor has BTLE connectivity,
Sorry, I can't give you a straight answer here. I use TTS4, and in the current TDA and TTA, something constantly breaks with each new update (as users report).
Thanks a lot Alex. May I ask you one more beginner question: Do you use an edge in parallel to TDA or the other apps? How does this work? DomI have to start the activity on both? Edge and Tacx?
I only use Tacx Genius connected to TTS4.
How does this work?
Thank you Alex, I actually figured it out. You have to connect only the sensors to the Edge, not the trainer itself.
