Vivosmart 5 Stress Levels Consistently HIGH
Every post I can find on this is locked for some reason. Coincidence?
I’ve had my HRV measured on a couple different devices and it was always very variable and a sign of good health. But, the Vivosmart 5 has my stress levels extremely high all the time. The only rest measurements I ever see are while sleeping and less than half the time there. Besides giving me a Stress level reading that suggests I should get to a Cardiologist as soon as possible, since this is also used as a sleep quality factor I hardly even get a Sleep Score higher than 50 and a battery level higher than 25. Since the HRV numbers themselves are not displayable on this device, I have no insight into what measurements are being recorded and used. As referenced above, others have had this same or similar issue and those discussions appear to have gotten closed quite promptly.
And, yes, I’m on the most recent firmware and have done several cold restarts. I haven’t set it back to factory settings yet and started all over, which seems a bit extreme since everything else seems to be working just fine. And, my heart rate measurements are fine and consistent with other devices and my resting heart rate puts my physical age back at least 5 years. It’d be even more if I wasn’t being dinged for stress and sleep, though.
I’d be better off with the stress indicator turned off and with it not being used or at least not weighted so heavily for the Sleep score.
So, is there a known problem with this that either can’t or won’t be fixed, or am I probably going to drop dead anytime?
Is anyone else having this issue? Please respond quickly before this thread gets locked too.
  • Hi . Thank you for input to this thread. I no longer use the Vivosmart 5 but have upgraded to a Venu 3 which gives much more accurate results (when compared to other non Garmin devices). However I am happy for you to view my Connect account as this may help with the problem. Please see below graph of the difference in my stress levels. I changed watches on 20th July, and this is reflected by a big dip in the graph below. I am based in the UK. I am not sure what version of software it was on but I regularly upgraded it to see if it would fix the problems so I would say it happened on all versions in that timeframe. The issue happened everyday and I also noticed that the HR monitor is 4-5 beats higher than other devices. Could this and other inaccuracies make the stress algorithm report a higher result? The results below were simply changing watches no other real lifestyle changes. Hope this is helpful.
  • Hi Maeve, It is everyday since I started using the device on November 14 my stress levels are high even at rest.  I checked my heart rate zones and they are set to the default.  My software version is 5.8.0.29 and I am located in the United States. You have permission to view my connect account.  It would be great to have the capability to turn off the stress feature since it is so frustrating to see high numbers even when completely relaxed.  I am considering going back to Fitbit or Withings and only using my Garmin for tracking my swims.
  • What is your resting Heart Rate and Max Heart Rate set to?
  • max is 153 and warmup is 77-92 there is no "resting" shown
  • Hi  is there any update on this please? Several of us have given permission to use our data for investigation purposes but we have not had any acknowledgment or update. I am getting frustrated (even though i no longer use this watch) with Garmin’s support as this issue has been going on for a very long time,
    thanks
  • Please take a look at your heart rate all day, if it is in your warm up zone or zone 2, you might experience higher than expected stress. Please consider adjusting your max heart rate and heart rate zones. For the most detailed support If you continue to experience higher than expected stress, please contact us at support.garmin.com
  • I've been getting this problem for the last week or two - much higher stress constantly than I actually feel, and last week I ended up with 950+ "active minutes" when the actual number was probably more like 30, with low step counts and just very work focused.
    (for the previous week, I did notice several times of my watch prompting a breathing exercise but only once for last week's wildly wrong reading.)
    I had figured the last vivosmart 5 software update broke something, until finding this thread.
    (for the previous week, I did notice several times of my watch prompting a breathing exercise but only once during last week's wildly wrong readings.)
    I had figured the last vivosmart 5 software update severely broke something, until finding this thread. But it's annoying enough that I don't trust any of the readings anymore and am very likely to go with a different brand entirely for my future needs.
  • I am experiencing exactly the same thing you describe, and it's VERY frustrating! Except for when I'm doing a work out or activity where it doesn't register stress level at all, the rest of the time, it says my stress level is off the charts! How can that be, when I'm resting, sleeping, relaxing? I am in excellent health and very active for my age (67). This stress indicator issue needs to be addressed and fixed, as it has become a source of stress in using this watch.
  • I am experiencing exactly the same thing you describe, and it's VERY frustrating! Except for when I'm doing a work out or activity where it doesn't register stress level at all, the rest of the time, it says my stress level is off the charts! How can that be, when I'm resting, sleeping, relaxing? I am in excellent health and very active for my age (67). This stress indicator issue needs to be addressed and fixed, as it has become a source of stress in using this watch. Garmin, can you do something to fix this??
