[Garmin Vivoactive 5] I have issue with volume control, I can't change the volume down (it's always maxed out) I can't even listen to music because its so loud. Every other button works (loop, choosing songs, switching between playlists etc.)
Your Garmin watch has been designed to work with most Bluetooth-compliant headphones. Not all headphone features will work with Garmin watches such as volume control, pause, or skip. Audio performance and Bluetooth range will vary across brands and models. In this case, you will want to try another set of headphones or use your phone to reduce the volume.
Surely volume control should work across all connected audio devices? I would think it's a safety hazard to have volume maxed and not able to be reduced? (I have the same issue.)
How has this not been addressed? Looks like this has been an issue for years. It's reason to not buy a Garmin.
I have this issue too, with JBL reflect flow earphones. Any solutions Garmin
