I've been wearing the Vivoactive 3 for over three years now and I'm thinking of upgrading to newer model Garmin. Several times my pulse ox monitor has read a heart rate up to 30 beats slower per minute than my Vivoactive 3. Is the heart rate monitor on the Vivoactive 5 more accurate than the one on the Vivoactive 3?
Recently my mild to moderate mitral regurgitation has started causing symptoms again so my doctor said I should start keeping a closer eye on my heart rate (checking for AFib) until they can get the results back from my heart monitor and my echocardiogram (and even beyond the time when we get the results). I tried the Venu 3 because it has the ECG feature and I thought that would be great in checking for AFib. But I have bradycardia (lower than normal resting heart rate...usually between 43 and 46 bpm) and the Venu 3 can't check for AFib if your heart rate is under 50.
I've thinking the Vivoactive 5 might be the best upgrade...but only if it's heart rate monitor is more accurate than the Vivoactive 3.
Thank you for any and all help!
TripleB
