New Vivoactive 5 owner here. The watch goes into “blue triangle “ mode whenever it is unplugged from the charger or PC…when it’s plugged in, it shows 100% battery ….any thoughts on how to fix this? I have tried to reset the watch but no change….
Please reach out to your local Garmin Support team to look into this for you.
I held the top right button down for 10 seconds, waited 10 secs and then held it down again for 30 seconds. Sorted for me, was just about to raise a ticket!
Just started having the same issue. Thank you for commenting your solution, it worked for me!
TY, same issue here and this worked.
I’ve just had the same issue randomly on mine
I tried the 10sec/30sec A button solution. This worked for me, or appeared to. After it looked like the watch was working again, I tried to start an activity and it went back to the blue triangle again. This has happened three times in a row this morning.
This worked for me, or appeared to. After it looked like the watch was working again, I tried to start an activity and it went back to the blue triangle again. This has happened three times in a row.
This Youtuber has a fix: www.youtube.com/watch
Wondering if server is down? Mine has done this twice today. Seems a coincidence that alot of us are having the same issue.
