Venu 3 recording weights lifted in kg
Hi
I have the Venu3 and have set it to record my weight and the weights I use as KG but when I did a HIIT workout today and then went to edit the weights I used it only allows me to record them as lbs.
Any idea?
Thank you
  • It’s likely your watch is set to metric, but the Garmin Connect app or your web profile is still stuck on imperial. Try going into the Garmin Connect app > Settings > User Settings > Units and make sure it’s set to Metric. If it already is, toggle it to lbs and back to kg, then sync your watch. That usually "reminds" the app to use kilograms for your activity edits.
