Has anyone ever been able to resolve this? I have done a hard reset and even set up a guest wifi and the watch is unable to detect any of them. It worked absolutely fine until a few weeks ago.
this is what I've found and the first bullet helped me solve the issue:
If parental controls are enabled for the Wi-Fi network, the watch may display "No internet connection" when attempting to connect. You will need to remove parental controls to fully connect the watch to that Wi-Fi network.
Wi-Fi networks that require you to log in on a browser screen, also known as captive portal, are not compatible with Garmin watches. You will need to use a different Wi-Fi network to connect with the watch.
taken from here: support.garmin.com/.../
Also, note that Garmin Vivoactive 4 only recognizes legacy Wi-Fi protocols, that is 2.4 Ghz b/g/n, not newer ag (Wi-Fi 6 standard)
