New Update Issues Battery draining, no green light, no messages
Hello. My vivoactive 4 just updated and now I am having many issues. My battery is draining very fast (it went from 100% to 68% in an hour) there is no green light sensor so nothing is tracking (HR and such) andoni messages are coming in.
The backlight is very low and it is connected to my phone. I turned it off and on. Should I do a reset?
  • I have exactly the same issue (battery draining fast and no green light) with my Vivoactive 4s.
    Under SW versions I could see that the following components are without version number.
    Sensorversion - 0.00
    WHR-Version - 0.00.00
    BMX - 0.0.0 (!)
    I suspect that an error occurred during the update to version 6.90 or the sensor update.
    Resetting the clock did not solve the problem. Hope that we get a solution for this.
  • Call customer service. I did and they really worked with me for days trying to get it to work. In the end, they're sending me a new watch. Mine is 2 years old! Great customer service.
  • I had the same problem when I updated it to 6.80. I tried restarting, resetting, factory resetting, and so on, but I couldn't solve it. Finally, I solved it in the following way.
    1. I've completely drained the battery of the watch. Maybe if you turn on the GPS, you'll be out in a day. Discharge until there is no screen even if you press the start button.
    2. I charged my watch more than 50 percent.
    3. Connect to the pc and run Garmin express. When I synchronized, it said there was an update.
    4. I disconnected it from the pc to proceed with the update.
    5. I saw a message for update it. After turning it off and on automatically, everything returned to normal.
    I think the sensor hub is not reset when VA4 start
    good luck!!
  • My battery life after the last update went down significantly as well. Also, during the last swimming pool visit, my watch shut downed itself repeatedly.
