Just got a GPS update two days ago. Since that update suffering massive battery drain. 8-10% an hour. VA4 is out of warranty.
Software 6.50 should be available to you now, or in the next couple of days. Please update the watch to 6.50 and see if the issue persists. If so, please reply with the following:
I had to remove the watch faces and reinstall. It’s good now. Back to about 14% a day without activities.
I’m sorry to hear of the battery drain issues that you’re experiencing. Let’s start by power cycling (turning off and then back on) your watch. If the battery drain persists and if you have any Connect IQ (CIQ) Content, especially watch faces, you may need to delete that content until the independent developer is able to update their app/watch face to function correctly (without causing a battery drain) with the new firmware version on your watch. You can use any of the 3 FAQs below to uninstall the CIQ content.
How to Uninstall Connect IQ App Content Using the Connect IQ App
How to Uninstall Connect IQ Content Using Garmin Express
How to Uninstall Connect IQ Content Using the Garmin Connect App
If you would like to submit feedback to the developer of the CIQ content, you can do so by clicking the link below and searching for the download page of the CIQ content. In the bottom right corner of that page, you will find the option to contact the developer.
https://apps.garmin.com/en-US/
If you have not already reached out to your local Garmin support team, we highly recommend doing that as well:
i already uninstalled everything so it is back in factory settings without any aditional faceplate or other things.
Without any succes. Also there is no way to have it bluetooth paired again with my phone.
Tried everything there.
Spend hours on getting back good, without any luck.
