Hi, I tested my VA4 with a different watchface - installed a regular default Garmin’s to see if battery drain changes at all. To my surprise, the difference is huge - 0.5-0.6% / hour with Garmin's WF vs. 0.8-1.1% / hour with my usual ActiFace. To make sure the results are sustainable, I used Garmin WF for several charging cycles. ActiFace remained inactive but still installed on the watch.
Now, Garmin watchface has a moving circle showing seconds at all times, this updating the screen every second, while I configure my ActiFace in such a way that the most often changing metric shown is minutes.
I wonder if anyone have had different experience with other watchfaces? This is about data-rich watchfaces similar to ActiFace, DataLover etc. Looking for better battery performance comparing to my current setup, while hopefully retaining data output.
