6.10 Battery drain fix
I never had a battery issue with FW upgrades until this update...After 6.10 it was horrible as with most of you, about 4%/ h so in total 1.5days
Finally fixed it by following a suggestion form a forum user , would suggest it for all and hopefully it will work for you:
  1. Full restart of the watch
  2. Full charge to 100%
  3. Completely turn off, wait 30 minutes
  4. Turn it on.
After this procedure, im back to about 0.5%/h. Actually a bit better than before!
Hope it helps! Cheers!
    0 Former Member over 4 years ago in reply to Garmin-Kevin
    Removing alarms solved the issue but hardly a great workaround. Battery life now back to normal.
    Any hope of Garmin actually responding to this and agreeing there is a bug, because it really looks like a bug?
