Vivoactive 4 and Cadence Sensor
I have a Cadence Sensor 2 and Vivoactive 4. The Vivoactive pairs with the Cadence Sensor on my bike, but I'm unable to set any settings for it.
Looking at the instructions on this page: https://www8.garmin.com/manuals/webhelp/vivoactive4_4S/EN-US/GUID-BC442CE2-4984-497C-A742-187CC2597FB9.html
It states:
  1. Hold B.
  2. Select Gear > Sensors > Speed/Cadence > Wheel Size.
  3. Select an option:
    • Select Auto to automatically calculate your wheel size and calibrate your speed sensor.
    • Select Manual, and enter your wheel size to manually calibrate your speed sensor (Wheel Size and Circumference).
When I hold B and select the Gear, I see Sensors, and then I see the sensor that I paired. Clicking on that I only see the options for Status (which just toggles whether it is connected), About (which only shows read-only information about the sensor), and Remove.
Am I looking in the wrong place?
UPDATE: The main problem is I don't see the cadence. I saw this, and thought I needed to set it. But I can't see the cadence anywhere.
