I have a Cadence Sensor 2 and Vivoactive 4. The Vivoactive pairs with the Cadence Sensor on my bike, but I'm unable to set any settings for it.
Looking at the instructions on this page: https://www8.garmin.com/manuals/webhelp/vivoactive4_4S/EN-US/GUID-BC442CE2-4984-497C-A742-187CC2597FB9.html
It states:
- Hold B.
- Select Gear.
- Select an option:
Select Auto to automatically calculate your wheel size and calibrate your speed sensor.
Select Manual, and enter your wheel size to manually calibrate your speed sensor (Wheel Size and Circumference).
When I hold B and select the Gear, I see Sensors, and then I see the sensor that I paired. Clicking on that I only see the options for Status (which just toggles whether it is connected), About (which only shows read-only information about the sensor), and Remove.
Am I looking in the wrong place?
UPDATE: The main problem is I don't see the cadence. I saw this, and thought I needed to set it. But I can't see the cadence anywhere.
