Battery doesn't last 4-5 days anymore. Instead is already on 48% after being taken off charge 14 hours ago. It was 100% charged 14 hours ago. Fix the firmware or roll it back. This is ridiculous!
Hello, I am sorry to see this is happening. I understand it is frustrating. I am working to get all of the information sent over and starting to reach out to customers with permission. With that being…
Still having this issue after update to 6.20 on Vivoactive4. It is connected with my morning alarm. Before the alarm goes off the watch will dim after 4-5 seconds (short delay setting). As soon as the…
Same for me, update to 6.20 did not fix the issue. No alarms in use so not sure what the issue is, as backlight does not appear to be on.
After turned off the watch, wait for 5 min and turn it on backlight issue has been fixed.
now let’s see if battery drain issue has been fixed .
good luck with that! I had backlight issue only once, and it was on 5.80 if I remember well. Let us know if it helps
Hello, I am sorry to see this is happening. I understand it is frustrating. I am working to get all of the information sent over and starting to reach out to customers with permission. With that being said, I need to know, have you completed a reset yet without success as well as made sure all CIQ apps are updated if they are being used?
Same situation here. As previously said I did:
After that, backlight behavior works as usual and battery life has been recovered. I am getting the same autonomy as previous release: 4/5 days.
Hope It helps.
regards
I’m having the same issue. I suspect it is the pulse oximetry. After the update all my alarms were turned off for some reason so I overslept. Then today I noticed my battery must have also drained over night and watch *** down due to critical battery level at 13:00 this afternoon. Watch isn’t even 6 months old yet and issue has only appeared since this update 2 days ago. If someone could get this sorted would be greatly appreciated.
I found an odd set of circumstances which seem to contribute. On another forum someone said it was related to the alarms. I have 2 alarms in the morning, after the first all is normal, but after the second the backlight will stay on and doesn’t turn off again (leading to serious battery drain). Solution is to restart the watch, but it seems like something in the alarms is triggering the problem, but not with every alarm…
