Some days ago I installed a temperature widget and it was working.
Now the same widget is showing "no data from sensor".
All other temperature widgets are saying the same.
Is this sensor working in your VA?
Thank you
What widget was this? It tells the outdoor temp or your body temp?
The widget is called simply temperature but I think every similar widgets are using the same sensor.It tells the body temperature but if you undress the watch you can measure the temperature of a room or the water when you swim.
