every time ai leave my phone downstairs and I go upstairs out if Bluetooth range my Venu disconnects from Bluetooth on my phone and needs to be reconnected manually. How do I get it to automatically reconnect?
I finally solved this on my Android phone.
Bluetooth connected automatically without problems when bluetooth was turned off-on or phone / watch was booted.
BUT
When bluetooth was disconnected due to distance…
Hello all. We currently are working on an issue where the Garmin Connect mobile app can prompt the connected watch to show a pairing code, even though the watch and mobile app are already paired, connected…
I only have the watch 3 days and it's bugging me.
Did anyone manage to get this sorted. I'm having the same issue. Using huawei mate20 Pro.
Also sleep tracking is so bad. It's. Saying I'm going…
Managed to get this sorted before I got the replies but yes you were right.
To resolve I needed to clear the Bluetooth cache and data on the phone.
Connection seems to be steady now so let's monitor over…
It is possible the device is not paired properly and needs to be re-paired. If the directions below do not work for you, I would reach out to Garmin Support.
From Garmin Connect Mobile app on your iPhone
Go back to the main menu on your iPhone
Open the Garmin Connect Mobile app
Thanks, done all of this and problem still happens. Will try contacting Garmin. Thanks for your help though.
Upgrade your watch to the latest version system/settings/software update and it should fix it (I’m on 5.10). I now just have problems with the app disconnecting from my watch and have to force close the app and reopen it but only about once a week or so rather than several times a day.
Hello! Are you using an iPhone or Android? If its an iPhone, are you leaving the app running in the background?
Hi,
I am experiencing the same behavior on my Venu (updated as well like my connect app). This is not dependent of the distance between my watch and my phone (android). I have several "disconnected" + few seconds after : "connected". this is very annoying. My garmin app is running in the background and I tried to remove/add again without any success. any idea ?
Experiencing the exact same, normal disconnect and reconnect when far away
But the random Bluetooth disconnevt happens with my phone right beside me and only notices due to the Bluetooth icon not showing on watch face and in shortcut mode blinking
And it is quite annoying as *** rather to have to remove it and repair since I lose my daily step goal, my Garmin pay and some other stuff as well?!
turn off the notification : I think it's not the good way as you will not know when your watch is connected or not ... The best way is to resolve the fact that the VENU should be able to stay connected and push the notification from SMS, phone, apps, etc ...
"Not connected" means the no notification from your phone.
@garmin : it's time to dig on that problem !
