@Garmin - flashlight, too many steps to turn on without button shortcut - fix this
Hi,
if you don't set the flashlight as shortcut to the buttons (I have more used stuff configured to it) but use it through the control menu there are too many steps to turn it on.
1. control menu (long press upper button), fine and a must of course
2. press the FL shortcut, a torch settings display appears but the torch is NOT turned on by pressing the shortcut
3. I need to tap the FL display again or press the upper button to turn it on (extra step, annoying)
Why?
If I tap the flashlight (FL) shortcut within the control menu I expect the torch to be turned on at that moment. It is ok to make the torch setting appear with it (brightness setting) but why do I need to tap it again to turn it on.
PRESSING THE FLASHLIGHT SHORTCUT IN CONTROL MENU MUST TURN ON THE TORCH RIGHT AWAY (I can adjust the brightness later). Really annoying.
