Request for little changes to how time is managed and shown
Hi, where can I put these request for little changes to how watch funtions? Or it his forum enough?
First, when the digital watch face is selected, minute progress appears as a line (like a worm) on the side of the clock. The function is good in itself because it allows you to see when a certain minute is full. The downside is that every other minute the line runs differently. First, the minute fills up, and in the other, it empties. It would definitely be better if the line (worm) were always lengthened, i.e. as it really is, more seconds per minute. When worm in 60 "second long" it would disappear and then start again.
Secondly, the same thing appears when running and performance tracking is on. For example, it can be seen if I run a pre-planned program with a 7-minute running section. During the section, the same worm runs along the edge of the clock, in minute fragments. Here it would be much better if the remaining time of that running section was displayed in the right proportion, i.e. that the worm would NOT be reduced in seconds but in proportion to the time remaining. When you are running, you could see in the corner of the eye how much of that green worm is visible, i.e. how far you are on that section.
