If you cover your watch with your palm when using the voice assistant (in my case Siri) to turn off work with it (the assistant), the watch does not disconnect from the phone and is available as a speaker - you can even listen to audio content through it. And the watch will no longer disconnect from your phone as an external speaker until you reboot it. At the same time, the battery starts to drain catastrophically fast. Once again, I did not notice that the watch did not turn off, and with the remaining battery charge for 3 days, it discharged in about 10 hours. This is a very annoying bug. I would like to fix it as soon as possible.
