Hiking with hiking pools - incorrectly counted steps and possible solutions
About a month ago I bought a Garmin Venu3 watch, I am very happy with the watch, however, as I often hike using hiking poles, I noticed that at the end of the hike I miss a lot of steps, I understand that this is due to the way the Venu3 counts steps, using the speedometer on my wrist, so when I use the sticks my hands are more or less static, and the watch cannot count every step.
Now I'm interested in the solution.
Reading the forums, I came across two possible solutions.
The first solution is to buy a device from the VivoSmart or Vivofit series, take it out of the case and put the device in my front pocket when hiking with poles.
I would like to know if this way the device will count the steps correctly and if it will add the missing steps to Garmin Connect.
If the above is correct, do I need to set the VivoSmart or VivoFit as the primary device, or are two devices being used at the same time and end up syncing with each other.
If I have to set the VivoSmart as my primary device, then I guess I won't be able to see other stats like heart rate etc in my activity with the Venu3.
Another solution is to buy a Garmin HRM Pro plus strap, however I'm not a big fan of wearing a strap.
If anyone has any experience, I'd be very grateful for it advice.
