Watchface datafields: recovery time / do not disturb / bluetooth
I don't seem to be able to choose the mentioned datasources as a datafield on a watchface. Do I miss something or is it just not possible?
- Recovery time
- Do Not Disturb status
- Bluetooth status
Or is there maybe another way to display the mentioned information?
  • Thank you for your report. Recovery time will be visible once you complete and save the activity. Once the activity is saved you will scroll down on the activity summary screen and the last page should be labeled Recovery.
    The Do Not Disturb status can be viewed by accessing the Controls Menu (Press and hold top-left). If the icon to the left of DND is green, it is enabled, if it is gray, it is disabled. If you do not see DND on the list of control, scroll down and select edit to add this to the list.
    Bluetooth Status will be on the same screen as Do Not Disturb. It will be labled as Phone Connection.
    If you have any additional questions please reach out to your local Garmin Support team.
  • It depends on the watch face. The Garmin built-in watch faces are quite limited in which data fields you can choose. Many third-party watch faces have a wide selection of data fields, including those you mentioned.
