Detailed battery life on the Venu 3
Been using the Venu 3 for the past 2 weeks.
Charged the battery last Wednesday night and now 7 days and 12 hours later, my battery is down to 3% (and it shows 12h left). So I am assuming 8 days of battery life.
Things I did:
Usual tracking of all metrics, my sleep is inconsistent (I had like 57-58 hrs of sleep in the past 8 days, on some days more and on some less), 2 hours of run using All system GNSS, 1 hour of badminton, 2 pulse ox readings (turned off for the rest of the time), no ecg and some 50-60 notifications on the watch ( did not reply to any notification from the watch, just dismissed them and  I deliberately turned off my phone Bluetooth to do this battery test).
So that is 8 days of battery life. Definitely far from Garmin's 14-day battery life. Does anyone else have similar issues? I am on the latest 8.25 firmware and do not use AOD. I was expecting 10 days of battery life at least.
Edit: Gesture mode on, Brightness set to 20%.
  • I had the exact same experience. Even without always on display switched on, the battery only lasts about 7 days.
    I can't say whether this would be better without the beta update because I went to the beta update 8.23 immediately after installing 7.07
  • Oh. I am on stable firmware, did not do the beta.  Let's see if any mod or anyone else can comment and let us know what is happening.
    0 Former Member over 1 year ago
    Well even worse but when turned off also gesture (neet to tap to screen) and brightness to 10% and oxy off, Move IQ off, BT connected to phone all the time, looks 9% per day... still in testing
  • Oh I forgot to mention that, mine is gesture enabled, brightness is set to 20% and the pulse ox is off. Let me edit the original post.
    9% day should last you 11 days.. But did you do any activity like GPS or any run or hike?
    Mine is 8 days, so approx 12.5%/day. It's not bad, I don't mind, but Garmin estimates 14 days (7.2%/day) and that is what worries me haha.
    Edit: My battery is at 96% and I shifted to turn off gesture mode, let me try this.
    0 Former Member over 1 year ago in reply to PRK91
    No no activity in case ~9% per day.
    So 14 days seems absolutely not realistic.
    Realy disappointed, thinking about change and use Huawei GT 4
  • Oh, I am not disappointed, I am just wondering what's going on. I previously had the Vivoactive 3 and the battery life was close to what Garmin had estimated.
    Oh, I won't change my watch for that reason, and I don't trust Huawei with any data haha.
    Bonjour,depuis la dernière mise à jour 8.25 aucun changement d autonomie pour moi,hr activé en permanence,ox activé pendant le sommeil, allumage cadran par geste,luminosité sur automatique, je tiens 8 jours sans activité GPS . j avais la même autonomie avec mon ancienne venu 2 plus.je pense que garmin annonce 14 jours avec tout au minimum,hr toutes les 10 minutes,pas d ox la nuit etc etc et la effectivement peut être que juste en mode montre avec cadran d origine on peut tenir 14 jours,mais dans ce cas là venu 3 n à plus aucun intérêt.
  • I kinda understood what you mean (by using Google Translate). Some of your assumptions are wrong. Of course, we can't use Pulse Ox (pulse ox drains the battery a lot), and Garmin says no activities, and use the default watch face and default brightness. In that case, the battery should last 14 days. Check the link below for a detailed estimation by Garmin for both Venu 3 and 3s.
    I had a 2-hour GPS workout and 1 hr non-GPS workout, but all the workouts use all the LEDs (for better HR accuracy), so my guess is 13-15% of the battery is gone just for that, which is roughly 2 days of Garmin's 14-day usage. So based on my usage (I don't use the default watch face, but use one of Garmin's pre-loaded, which shows the magnetic heading all the time), I should get like 10 days, but I am getting 8 days, 2 days off. It's not huge, but still noticeable.
    Link to Garmin battery life estimations: https://support.garmin.com/en-US/?faq=wRMnVRKL5i3YvvL05lqMi6&productID=873008&tab=topics
    well im surprised that garmin is not so precize have a look youtu.be/KAZJPQv6kiU
    seems GT4 has more precize heart rate and gps as well :)
  • HR is a function of many things. Skin color, the amount of hair on your skin, wrist size and watch size, and a few more. I know that video of Qualified Scientist, but he does mention that it is a single person, meaning the data is validated only for his wrist (and the same cannot hold true for everyone). On the other hand, have a look at DCR's review (Link: Venu 3 review) and you will find that Venu 3 HR matches the chest strap HR in almost every scenario (because the elevate v5 sensor is the same as in Fenix/Epix models). The same holds true for GPS, according to DCR, it is pretty accurate. You can also have a look at DesFit's Venu 3 review on YT.
