Can any one confirm what settings they are using to get the advertised 13 days battery life. had the watch since early Saturday morning. and its down to 53% now (so 4.5days) so maybe 10 days total based on this.
ive set the DND up although its annoying you cant set the battery saver mode to work like it does on an epix pro or instinct. Also not having a way to disable the wifi was annoying so i removed the network from the watch too
timeout medium
sensitivity low
gesture mode
brightness medium
ive tried everything and doesnt seem to change the battery life.
i have also noticed that there appears to be an issue with the garmin connect app and its connection to the phone to change certain settings. a good example being going to activities and editing the data fields on an activity profile. select the field you want to change and select anything... Time of day for example. the error pops up "settings unable to be changed" but then changes it anyway. any one else had this issue
