My Venu 2 turns off at around 20-30% of battery and is not able to charge more than 80-85%.
Also, charging takes a couple of hours, white previously it took 20-30 minutes.
Is anybody else experiencing the same problem?
Shall I ask for replacement?
If you search these forums, you will find that this is a common problem. What age is your watch? Seems that after 18 months the battery degrades quickly.
I have found, following advice in the forums, that charging significantly increase speed if you turn the watch off to charge now.
