Venu 2s not showing distance for walking
I have a Venu 2s and have the following issue when looking at the synchronised data in the Garmin Connect app:
  • Steps are recorded and shown
  • Distance is not show, except indirectly when I’ve recorded an activity such as a run.
Is there a way to get the app to display distance data as it does for steps etc?
  • If you tap on the steps in garmin connect it will show the distance as well as calories.  You can also select other watch faces that show the distance or add a distance field in one of Garmin’s watch faces that you create with the watch.
