I've noticed, that floors climbed credit is frequently too high. Fortunately there's a reason, given in Garmin's FAQ, that is very reasonable:
Walking into a warm building on a cold day or even walking near exit doors when it is cold outside may trigger excessive credit.
Garmin's FAQ about floors climbed accuracy
And yes, this has place in my case. Outside there's -1 to 0 degrees Celsius, and in the building it's 15 degrees C. And it's reasonable, that it may be an error on calculations in this case.
Well, how can I deal with it? Could I minimize this erroneous deviation?
Can this problem be resolved by calibrating barometer via GPS inside of the warm building?
Should I calibrate barometer outside via GPS, when the pressure (or temperature) outside will be higher?
