Battery drain on 3.40
For reasons I don't understand I am stuck on firmware 3.40.
Twice now I've had random battery drains and I suspect they've happened after I've done waking/running activities.
The first time i went from 58% to nothing while sleeping. Today I should have been around 60 to 70 percent. When I checked my battery I was down to 43%. I checked a minute later and I was down to 40.
I went from a vivoactive 3 to this because of the improved features and battery life, but I'm heading to have to charge it every day because of the random drain.
I have removed all third party watch faces long ago. I only have the preinstalled Garmin ones left.
What are my options? I'm stuck here
  • Have you tried rebooting the watch?  Press and hold the upper button until the watch turns itself off (~20 seconds) and then turn it back on.
    As far as being on 3.40, you probably have an APAC (Asian-Pacific) version of the watch.
  • Yeah. The second time when I noticed the drain I rebooted and it seems to stop it.
    But spot checks and restarts aren't a long term solution.
    Next time I will reset it. I'm hoping that helps.
    As for being stuck with an APAC version, I have had my suspicions. What's odd is I got it from Amazon US.
